ALRIGHT LADS, can u tell me how to fit the gsi sideskirts to my nova??????????????????
i've got the pop rivits and so on i just need to know how to fit em
chris
chris
apently ya can get instructions from vaux if you ask nicely.
they rivit on and use some clips to attach the outer bits.
or take em to a bodyshop and they should put em on for about ?30
gaz
Drill the holes on to ur shell and the clips should slide on if youve drilled the holes in the correct places!
that will make more sense when you see the clips and pop rivets thats how i did it only thing is the skirts dont meet flush like u think they would but oh well every nove gets that apart from gte/gsis
hope this is of help
Fit a clip in the skirt, one at the front and one at the rear, dab some grease or paint around the holes on the clip and offer the skirt up to the car in the corect position, push the clip areas to the car, with any luck this will show you where the holes need to be, fill in the other clips in the same way. Dab the rivets in grease to stop rusting around the hole.
