Page 51 of 56 FirstFirst ... 414950515253 ... LastLast
Results 501 to 510 of 556
  1. #501
    brotton , saltburn by the sea
    1,877
    All finished just wants painting
    Sent from my SM-A105FN using Tapatalk
  2. #502
    1,877
    Been very busy trying to get everything in order before the dyno day . Trailers all painted now . The top slick is the size im going to the bottom one is whats come off . Bearing in mind the bottom one is 9 inches wide . New wheels should have a much better roll out . Fitting twin pumps to deal with the new injectors and also changed to e98 ethanol fuel . New cams and pulleys fit . Fingers crossed it makes some good numbers
  3. #503
    13,604
    Covered trailer is cool, as is buying your fuel in kegs, haha. Head rebuild all finished then?
  4. #504
    1,877
    Yea all work done mate . 11th of april for the dyno
  5. #505
    1,877
    15mm.id ptfe no excuse now to not have enough fuel
  6. #506
    Sep 2012
    Sutton, Surrey
    3,752
    Never have enough fuel! Progress looks good mate
  7. #507
    1,877
    New stainless steel filter and lambda controller
  8. #508
    Club Member Club Member
    Jun 2005
    Dereham Norfolk
    1,013
    Where/what are the pumps mounted on to?
    Need to mount my pump but not sure where, whether to mount it as per a GSi or go different.
  9. #509
    1,877
    Mine are mounted to the flat floor . The pumps should be gravity fed from the tank and not having to suck the fuel in . Having said that i did used to have my pump up in the engine bay but it wasnt ideal and just makes the pump have to work harder .
  10. #510
    Jun 2005
    Dereham Norfolk
    1,013
    Glad I asked that.
    So I need to have my pump lower than the tank outlet which is good.
    Cheers for that.
