Looks like it will fit off pictures but anyone know 100 percent if it does. ? I carn find a 2ltr 8v sump anywhere.
 C20xe sump on c20ne
 C20xe sump on c20ne
				It will definitely line up as most c20xe owners use the bonded 8v sump gasket. Not sure if the pick up will cause you any grief
				Well the gaskets deffo fit as i use one and i know you can build an 8v bottom end into a 16v so i cant see why it wont work
				Was thinking of using one as the 8v ones are hard to come by. Cheers
