Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Track day problems
    Apr 2012
    49
    Default Track day problems
    Hi all, have a c16xe nova track car, the problem im having is fuel starvation on long fast corners. Just wondering has anyone got any advice without spending big money.
    Thanks.
    Dec 2013
    Kings Hill, Kent
    1,889
    Change of fuel tank I'd say mate, you want an MPI tank which has the high pressure pump in the tank.
    Dec 2013
    Kings Hill, Kent
    1,889
    What was the original nova?? Engine size?
    Apr 2012
    49
    The fuel tank is a fuel injection tank with a motorsport fuel pump inside it.
    Dec 2013
    Kings Hill, Kent
    1,889
    Quote Originally Posted by sibzy View Post
    Hmmmm
    Then I'd say you need additional swirl pot of some description.
    Does it only happen at a certain fuel level? Under 1/4 tank for example. Another option might be to cut the tank open and add baffles or tank foam.
    Jun 2002
    Poole, Dorset, United Kingdom
    8,490
    What fuel pump is it?
    If it’s an eBay special then I might be suspicious of that.
    Has the pump been tested?
    is it correctly located so it’s filter (do check the filter) is picking up from the bottom of the tank?
    Apr 2012
    49
    Hmmmm
    Was thinking of a swirl pot but wasnt sure if i needed anything else with it or would a bulk head mounted swirl pot do the trick?
    The fuel pump is a walbro 255 and its new.
    Apr 2012
    49
    It happens if its under 3/4 full.
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    What tyres are you running? Back in the olden days, my Gsi tank and external pump used to struggle if I was on slicks
    Apr 2012
    49
    Quote Originally Posted by Will F View Post
    Im using toyo r888r's.the grip is excellant.
