One of them looks perfect colin.
Inlet all welded up and trial fit just need to set the cable holder in the correct place once it arrives and weld that in place . now just setting new turbo up to build a hood exit exhaust and dump tube.
Cable sorted thanks to colin and exhaust fits nice . Screamer pipe to make next
My new "cardboard fiber" bonnet
This "thing" is gonna be an animal!!!!
Cheers mate i hope so . Slowly getting all the stuff that has been strangling the motor swapped . Hopefully with this setup it will flow alot better so i can get the air into the motor that it needs . Also trying 50% methanol this time round at the dyno
Boost pipes all sorted. Fiberglass bonnet fits spot on . Just another hole next to the exhaust to cut for screamer pipe. Carbon effect door cards to add a bit of weight and hide all sharp edges behind . And another pair of equal length shafts as spares .
Just bottom rad hose to sort out now then strip it all down and rebuild it all properly ready for the dyno .
Wrinkly
Looking well pal. Good stuff the vht wrinkle paint. I did mine with it.
Much better
