Iam gonna be fitting my new screen and rubber any tips on this? Best to use window cleaner as lube?![]()
I always use washing up liquid and insulated wire it seems to pull round easyer than string . Done loads over the years without a problem
Ok will give that a go. Is it a case of making sure the rubber is nice and lubed up. Thanks pal.
Washing up liquid is not a good thing to use as it contains a lot of salt, window cleaner works well, and make sure you use a good strong cord, I find the stuff used on washing lines works well.
Rear or front?
I used washing line as it has enough slip on it so didnt need any lube, fnaaahhh
Don't bother with any sealant/adhesive either.
Ok cheers lads.
