Ok so I'm doing a timing belt change before I put the engine back in...
No no matter how many times I turn it over by hand I can't get the cam shaft pulleys lined to the notches on the cam cover and the crankshaft pulley lined to the pin...
I have the camshaft pulleys lined up but the crankshaft is out do I just put it back where it is now as it was running fine? Or do I line it up as it should
cheers
alex
