Hi, just wondering what are the best injectors to put into a c20xe engine? It's going to be a good spec'd engine but I'm not sure which are the best injectors to use to get as much bhp as possible...... Cheers
On standard Ecu wether chipped or not cream for 2.5 bar and blue for 3 bar reg. All bigger injectors will do is make it over fuel.
I'm gonna get a mappable ecu, omex 600 maybe I haven't really looked into that side of things yet, would cream or blue still be my best bet with a mappable ecu?
Presumably creams @2.5 flow the same as blue@3?
So to get the largest flow combination, creams@3bar would be the obvious choice. But thats not to say the spray pattern isnt affected by them running .5b higher.
You could just run on batch and youd have more than enough duty cycle to get the fuel in you need.
