Results 1 to 10 of 10
Thread: Corsa C 1.0 missfire
    Junior User
    Jan 2014
    Chepstow / Gloucestershire
    74
    Default Corsa C 1.0 missfire
    After a bit of help - my sisters 2002 Corsa 1.0 (3 cylinder lump) has picked up a missfire.
    It runs fine for around 10 mins then it looses all power and engine management light comes on. It is literally gutless, I drove it today and it would not go over 40.
    I have changed plugs & coil pack and no difference, has anybody experienced this before?
    Cheers
    Chris
    Apr 2008
    Aberdeen, Scotland
    4,025
    My mates corsa was doing that. It was the crankshaft sensor iirc.
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Is the eml on at all?
    Junior User
    Jan 2014
    74
    Thinking about it, it have a feeling it was the eml light.....what's the thoughts on that?
    Club Member Club Member DaveMarshall's Avatar
    Jul 2004
    Swindon
    525
    Could be coolant temp sensor, poss ecu, they are prone to playing up when they get warm or could be something else altogether.
    Dave.
    Mar 2009
    Durham
    8,333
    It's missing a cylinder.
    CTS is always a massive issue that people overlook.
    Junior User
    Jan 2014
    74
    Thanks for the help so far guys. I plugged it into a friends diagnostics tester and it said missfire on all cylinders - have fitted a new coil pack & plugs to it and it's still doing it! Is CTS a Coolant Temp Sensor? It's doing my head in! Any more help out there?
    Aug 2006
    I live inside your pants
    4,527
    More likely to be cam or crank sensor it will run with either of them working albeit rough. If you unplug on of them and it dies, it will likely be the other one that is faulty.
    There really isn't much else other than a maf and 2 lambda sensors.
    Apr 2008
    Aberdeen, Scotland
    4,025
    As per my reply above, try the crankshaft sensor, my mate had the same symptoms as you've described and that was the problem.
    Senior User mowgli's Avatar
    35,194
    is it getting hot?
