Hey guys I forgot when I had my
Mock engine and box in the bay to try My loom on and see where I would need to drill a hole in the bulk head to run the loom through anyome have any pics? As want to drill it before I paint the bay
52 mm Starret cutter is what you want, I always went through the antenna hole, just make sure it clears the bonnet hinge, when it's down and be careful of the loom is still in as the holes aw will wreck anything in its path
Some people run the loom through the box that bolts on to the bulkhead near the pedal box if that makes sense .
Any pics?
Ok had a look at drilling a 52mm hole through the we cover that bolts
Onto the bulkhead I figured it out that it would be brave and close to the brake pedal mechanism once fitted anyone done this and knows first hand?
