You cannot achieve the same straight line speed with a lower cornering speed, unless that car is topped out at the end of every straight, where does the extra acceleration come from?
And how do you 'work harder' on the straights, than being WOT?
With a poor setup you will have less grip which forces you to brake earlier, and for longer, but at a much lower rate so much less energy in the braking system.
