how do u get the bits of da dash on either side of da clocks,m i have un dun all da screws n dey dont wanna cum off!
for the centre vent housing, u have to prise out the left vent n theres a screw behind it n to get the surround off that holds the light switches u gotta take off the light switch n take out the barrel behind it as well (which is hard) n theres 1 screw behind that as well. ull need sum kinda metal strip to prise stuff out.
cheers. do i just pull da light switch off?
if its the toggle switch for the head lights youre on about; good luck. if you mean the hazard; give it good ol' tug.Originally Posted by 1.2 NOVA
the light switch u pull it towards u and theres 2 lugs either side u got push them in usin like 2 screw drivers n get sum one else to pull it off, its a pain in the arse basically ::
Just read the manual, it'll tell you step by step as well
