well bought some shafts from egay with cv's says he's a user on here called cheezy
also just purchased everything else needed to finish it so just gotta wait on it all coming get it started (hopefully)
That would be me then
haha yeah it will be
its official all mk1 clios should be scrapped :/
, the flange just after the cat was ****ed so i cut it out and bough a clamp on connector to replace it
exhaust is 2" so i bought a 2" connector from my local parts
ive just spent the last couple hours bashing **** out of it to get the connector on as i measured it and they were only 45mm
so heres me lying under the car trying to hold the exhaust up and bash it on at the same time while my mums standing there going "whats wrong? isnt it fitting?"
that is 1 thing i absolutely hate when im trying to do something, i had my lump hammer ready to launch at her
Aw that's no way to treat your mummy
im sure she does it just to annoy me
well went to change my cam pulley today and my mates borrowed my tools and lost some of my sockets again
i ended up sorting some of the wiring, my plugs on my loom do not fit the radiator or the fan so i had to cut the plugs off and put spade connectors on the end
how do i figure out which way they go though?
ive got the coilpack on the brake servo atm untill i can find somewhere for it, the leads are from a sierra so are quite long so that helps
i also need to find a place for my filterking regulator too
any ideas?
also in my picsw you can see the crankcase breather coming up but it dosnt line up with the inlet on the cam box? i cannot adjust the pipe at all and it dosnt seem to be bent out of shape or anything
back to work tonight for 3 days so wont get much done, once my shafts arrive ill get them on and get the car back on the ground, ive put 3 litres of oil in atm and its barely reading on the dipstick hopefully its just because the cars on ramps and is only 3 litres
so my local scrappy has thousands of crs but cant find me an inertia switch........ lazy coonts
