i got a 1.2i at the mo. i was just wondering wot the biggest engine i could put in without having to change all the gearbox etc.......
cheers
cheers
It depends on what you mean by without changing the gearbox?
You can buy engines and gearboxs together so you could fit a 2.5 V6 stright from a calibra, or a 2.0L 8v, 16v or a 16v turbo with a F20 or modified F28 gearbox.
All depends on what you want to do, you could fit any engine you want.
I've seen a mini with a V8 lump in it and another one with a 2.0L 16v red top lump in it.
i kinda meant without changing all the engine mounts, somthing that will just basically go straight in
Ah i see. PVD do a conversion kit that comes with modified mounts eg the bar from bodywork to engine. Check the website out, go to
www.pvdnet.co.uk then click the M-Tech icon.
But you can buy modified rubber mounts which does the samething. To find out more about them go to
www.topbuzz.co.uk which also tells you about how to fit a 2.0L lump.
Hope that helps you more.
1600 8v would be the easisest, cheapest, quickest.
would a valver be much harder, as i either wanted a 1.4 16v or a 1.6 16v?
Only worth fitting one of those if your prepared to spend ?kk's on moding it as the 8v's can be tuned muche cheaper.
ill have to have a think,,,
cheers lads
