Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Remove key and engine runs on
  1. #11
    13,605
    Yep just as Alex said, I have multiple ign live circuits running off the relay straight from the killswitch.
    I've wired in the relay correctly AFAIK, done the same as I have for the air horn and that works OK.
  2. #12
    m-teqbodyrepairs.co.uk Club Member 16v Nova Kev's Avatar
    Oct 2007
    dumbarton
    6,645
    this happened to me. in my case it was dodgey copper track on the clocks.
  3. #13
    13,605
    I'll try it without the clocks, worth a shot.
  4. #14
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    That is not your problem.
  5. #15
    Nov 2005
    s****horpe
    592
    i had a problem with my astra td and it was alternator related
  6. #16
    13,605
    Here's some more test findings, think its something to do with the way I've wired the relay as if I connect the new ign live wires to the old one it all works fine
    Pull original switched live off relay during "run on period" and engine stops
    Measure original black wire during "run on period" and its showing 4v and new output is showing 12v
    wtf is going on?
    I have the relay wired up as follows:
    So
    30 = to battery (via fuse)
    87 = to output (ECU ign live)
    86 = Ground
    85 = Original ign live wire
  7. #17
    Sep 2006
    Sunny Sunderland by the sea. Well, inbetween there and Durham.
    16,544
    Unless you have typed that wrongly, 85 and 86 are the wrong way around.
  8. #18
    13,605
    I've tried it both way rounds, thought it was interchangeable?
    I've semi resolved it now. The ignition live I was using was the one that originally ran to the front of the car, I think it was for the coil? This looked like it was actually unfused and split from various other black wires on the bulkhead...?
    By running this one directly to the ECU ignition live (through a fuse) and using the fag lighter ignition live on the relay it seems to work.
    Can anyone explain why this is?
  9. #19
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    The way youve got the relay wired is fine. Personally I wouldnt of done it like that, but it should work fine.
    And its better how youve wired it up now, with the ecu directly to an ignition live instead of through a relay.
  10. #20
    13,605
    Frick knows why it was behaving weirdly then. Any ideas where I should take a new ignition live from for the relay? Just anywhere as it won't be adding much load?
