i do alot of valeting from home and i find that the meguires tyre gloss gell is the best. you can also use it on any bump strips or none colour coded bumpers. it helps turn them from tired grey looking to shiney new black.
i worked as a valeter for abit and we used tyre slick which i aquired allot as i did with a few other things! its a silican based liquid we used was worked well!! you just have to try not to put two much on beacase if you do it can flick up the side off your nice clean car
armorall tyre shine foam i use,60%of the time it works EVERY TIME!
yea megs gel works a treat
I would agree with the above megs endurance tyre gel looks awesome and smells good enough to consume! Honestly
meguires tyre gloss gell is the best + 1 too
Concept is serious stuff. Only comes in a gallon tho!!
there's a few good produtcs but i use trafalgar because ive got a few gallons off the stuff it works a treat! you dont need to put two much on though and it lasts for days!!
armour all tyre foamOriginally Posted by Matt
You can get some cheap tyre foam stuff out of wlkinsons and it works really great !
