Page 3 of 19 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 188
Thread: *HOW TO* fit a Smallblock XE. (1.4/1.6 16v)
  1. #21
    Sep 2009
    East Yorkshire
    470
    Could peeps that have done this post up pics of what they did about tensioning the alternator belt if you remove the PAS pump and Aircon pump?
  2. #22
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    Depends if you run wide multi v belt setup or run single V, some people need the single V to clear the chassis leg.
    I personally run multi V using the standard sport (with no aircon or PAS) setup with auto tensioner.
    http://i252.photobucket.com/albums/h...6/HPIM1401.jpg
  3. #23
    Senior User djbrowney's Avatar
    Apr 2005
    kings lynn
    4,334
    Quote Originally Posted by AW06
    i have got to run a muilt v belt, how is it some people say they fit, some say they dont ????
  4. #24
    Jan 2008
    In Space, Lost.
    11,566
    I think its nova tollerances tbh
    Southie (who also runs solid mounts) dont have much clearance with the single V iirc. His is mk1, OFC mine is mk2.
    Mine has plenty of space, Best thing is to suck it and see!
    Edit, If ya want il find a pic of the clearance on mine.
  5. #25
    Sep 2009
    East Yorkshire
    470
    Dont have the part numbers for this setup do ya buddy?
  6. #26
    Jan 2008
    In Space, Lost.
    11,566
    I dont, Il see what pics i have of the setup, but it basically the lower alt bracket with the bolt holes for the standard vauxhall auto tensioner (could be called self tensioner), Just a bit bit of alloy.
    Edit; Bingo!
  7. #27
    Apr 2008
    margate/kent
    544
    mines set up the same as aw06's but i dont know what belt its using or tensioner as i bought it off a mate already done and sold my other engine, mines a mk1 and i dont have a huge amount of clearance, i also dont mind putting pictures up later
  8. #28
    Junior User
    Jul 2010
    82
    hi mate ive put a 1.4 8v engine in my nova but need some help wiring it... i have the 9 pin plug that needs wiring into the spi loom or can you not do that. also can you put an ecu of a corsa mreg straight onto the loom that came off the corsa also and put it in my car would it work... it dont need promgramming does it...
  9. #29
    Apr 2007
    280
    call me thick but is it the linkage that comes from the car that you chop or is it the bit that slides into the linkages from the car. its a 4 speed btw
  10. #30
    Nov 2008
    toquay devon
    126
    no if you lift the gear seletor boot in the car there's a plastic lug on the right hand side that need's cutting off
