ok, i have now written up a list with prices
for sale i have alot of parts, now with prices
they are majoprly c20xe, and astra gte bits. with a few LET bits
5 2 x rear number plate lights £7.00
8 12 x c20xe fuel lines, with good lengths £8.00
12 3 x astra gte wing bottle neck £9.00
16 rear springs, astra gte standard height SOLD
17 astra gte center console £13.00
18 strut top mount, astra £10.00
20 2 x top parts of the gear linkage set up. £10.00
31 pair of indicator stalks £10.00
32 a few steering cownlings, adjustable and non adjustable £10.00
33 a single red electric mirror, with crack in £10.00
35 4 x piece of wing mirror glass £10.00
37 3 x thermostat housing £10.00
40 indicator £12.00
41 13 x different engine mounts £12.00
42 2 x c20xe dipstick holders £13.00
43 radiator fan £18.00
44 2 x starters, not sure what for, I reckon both xe's £18.00
46 2 x xe baffle plates £10.00
47 a set of rear lights £18.00
48 a set of headlights £18.00
49 master cylinder + bottle £15.00
50 k&n panel air filter £15.00
51 ally gearbox clutch lever £15.00
52 coil, astra early type £15.00
53 coil astra coke can style £15.00
54 astra gte K+N air filter bracket £15.00
55 oil pressure sender, light only, not guage £15.00
56 a heatshield for something. £15.00
57 Big ally air filter pipe 90 degree bend £15.00
58 5 x AFM's mostly 4 pins and one 5 pin £15.00
59 XE dizzy cap £15.00
60 brand new diesel cambelt £15.00
61 2 x ECU Motoronic both GL I think £15.00
62 Turbo top cover, chopped for strut brace £15.00
64 key less door handles, corsa conversion? £15.00
65 astra GTE lower console and switches £15.00
66 DTM piece of glass £15.00
68 oil pick up pipe £15.00
69 4 x cambelt backing plates £15.00
70 3 x crank sensors £15.00
71 adjustable steering coloum with barrel and key £23.00
72 1 x LET camshaft £20.00
73 1 X late XE camshaft £20.00
74 early Astra washer bottle with two pumps £20.00
75 a set of dark blue electric mirrors £20.00
76 2 x xe throttle bodies £20.00
77 lambda sensor £20.00
78 XE valves, x 15 £20.00
79 15 x cam lifters £20.00
80 pair of rear calipers of astra gte stamped with 35 on £20.00
81 2 XE inlet manifolds £20.00
85 Clutch + housing for potted flywheel £28.00
86 a pair of cambelt pulleys £25.00
87 injector rail £25.00
88 2 x XE conrods and bottoms £25.00
90 fuel pressure regulator, £30.00
91 bottom pulley round tooth, with woodruff key £20.00
92 2 x early XE cam shafts £30.00
93 koni rear adjustable shock, astra £38.00
94 v6 equal length drive shafts £38.00
prices INCLUDE postage.
pics on request or can be seen in this thread:
http://www.pngclub.com/forum/showthread.php?t=128142
