i have more chance of landing on the moon
Its Still the same, waiting on another ECU.....
Just to check with yours, does the plugs on the ecu match the loom ecu plugs (tis prob with mine)
Everything else on mine is working and connected. Just the throttlebody is the balls up. Problem when you get parts given to you free I suppose![]()
Would have thought it would bring up a ECU light but meh.
Well I would have thought that myself bearing in mind it wasn't plugged inOriginally Posted by AW06
not till it runs matey...
just to let you know, the c16xe and x16xe have the same TB's with the same sensors
i fitted c16xe management to my x16xe, all i had to change was the knock sensor, ecu water temp, o2 sensor, on because the plug were diff![]()
Right as I had put this post up my mate has since put a x16xe throttle body on which has the tps![]()
Turned it over and ...
... Still the same, so tried flash codes again and it's now coming up with a 93 code. I'm pretty sure this is the finishing code??? Anyone help![]()
Is the way to reset the ecu's on these engines by unconnecting the battery and turning the ignition on and off 3 times?
where about in West Yorkshire are you?
mine has its mot next week, and fancy a road trip![]()
Reset what? i belive you clear the codes by leaving the battery unpluged for a while.
i left mine for approx 20mins, and the codes cleared
