Page 1 of 25 12311 ... LastLast
Results 1 to 10 of 243
Thread: Nova 3.2 v6 (z32se)
    Contributer Club Contributer david dixon's Avatar
    May 2004
    2,758
    Default Nova 3.2 v6 (z32se).....Turbo
    well here is the start of what will in end in a 3.2 v6 nova, we managed to find a clean nova with only 46k original miles! its a fairly clean/ solid car, the floor, doors, legs are just about what they were like from the factory, the only places where there is a bit rust is slam panel, one patch on the inner wing and just starting to show on the arches, here's a few pics of the car.
    more to be added........
    Team Griffin Nova 2.8 v6, 10.9@124mph santa pod 2012,
    UK's Quickest N/A Nitrous FWD
    May 2004
    2,758
    first thing to do was brakes, so we fitted some 288mm v6 front discs and calipers.
    then started collecting parts for the build of the engine to make sure everything was up to scratch.
    Then bought 2 back boxes so we can run twin exhaust systems straight from the manifolds back.
    than just a couple of car mods.
    a few more parts
    here's a few more bits collected for the build which need cleaning and painting.
    competition engine mounts
    Nova strut brace which looks like it'll fit around the inlet ok.....soon find out though
    some poly bushed bottom arms and rose joint tie bars with the option of lowering for the 6 speed boxes etc.
    and we are going to use the bilstein front shocks for it.
    May 2004
    2,758
    we then moved on to giving it some seem welding just to be sure....
    Then it was all clean back, rubbed down, primed and painted in the colour its going to end off, this is straight out the gun, needs a quick rub back and polish.....
    May 2004
    2,758
    we cleaned out the rear arches out and sprayed some stone chip around to keep it protected, no welding needed which i was happy about!
    then it was time to give the speedlines a lick of paint (black to match the future body colour)
    then we tackled the 3.2 lump;
    first thing we did was strip it down to the bottom end and check the bores and piston movement (all was fine there)
    we also removed the paper filter housing to return it to the old style filter fitment and also removed the oil cooler as we are going to fit a front mount aftermarket item.
    we then fitted a set of modded 2.5 v6 heads (smaller chamber for higher compression) fitted the 3.2 exhaust valves (sodium filled), 3.2 cams G/J, matched up the inlet ports to a 3.0 inlet divider
    then did a pikie gas flow to removed the large lump the restricts the v6 engines on the exhaust sides (alot of meat come out of here)
    then started putting it all together
    the f18 box needed modding to fit the saab style gearbox face on the 3.2 block!
    May 2004
    2,758
    more updates will come in the next week or so, hope you like
    david
    Dec 2007
    dublin
    577
    sweet
    Jul 2002
    8,110
    Great project mate, something quite different. Should shift and have plenty of grunt with that 3.2 in the front.
    Interesting choice of gearbox. Will the F18 be able to take the power/torque of the lump?
    Can't wait to see this fully finished.
    May 2004
    2,758
    yeah it should be fine mate, we ran a saab 2.5 v6 with a 75 shot on a f20 and it took it ok, with this being a long derv box it shouldn't take it out of it too much!
    David.
    Dec 2008
    Coxhoe/co Durham/ United Kingdom
    2,794
    that engine bay look mint don't no if it was like that the last time i was over and the engine look mint. wat you think it will do at york
    May 2004
    2,758
    well the 2.5 did 12.5 so hopefully with a turbo on this one we'll see 11's but i suppose we can only wait and see mate!
    david.
