Started with a MINT 1.2 LUXE:
and this is where it stands:
I need to seam weld the original chassis rails to what remins of the floor and plate up some bits that I have removed because they were corregated. Then I can weld in the engine rails and think about fitting the Corsa C sub frame.
Obviously the original rear beam is comming out at some point.. at the moment it makes the car easy to move around having it there :D
