Get these pics up - Really good build so far
looking goood mate :D
" If you aint breaking you aint racing! "
Engine, radiator & fan bailey header tank and all pipe work fitted. Camshaft cover will be sprayed silver.
Started to under seal the inner wings. Rubbed down where needed then sprayed with stone chip, need to do up to the doors then a coat of waxoyl under seal. Also drilled the holes to hide the wiring loom.
Decide I’m going to get some rose motorsport hoses. Don't know what colour to go for though. I was thinking black. What do you think? any ideas?
Black sounds good.
Black does sound good, keep the red to the engine bay
Had my fuel tank back tonight from been sand-blasted, so started to spray it silver ready for fitting to the car. Also Heres a list of the other work i've got done to the car over the last week
- Finished painting the inner wings with under seal
- Wired all the engine up
- Extended the headlight loom
- Fitted the battery
- Started to re-fit the front suspension
- Drilled a hole through the boot floor for the fuel pump wire
Will update with pictures asap
Wow has that just rolled out of vauxhalls nar thats mint that one mate
Looks well.
Remember fit grommets to those holes that the looms running through.
Old XE track car
Nice project you've got going on there fella.Originally Posted by Courtnova16v
Love the bling Bailey header tank & gyppo hose clips.... :D
cheers for the comments so far. I will be fitting grommets to the loom holes just not sure where i'm going to get them from. Any ideas where I can buy new? Also I will be getting for new rose motorsport hoses soon so hose clips will be changed then
