Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: What would you do?
    Newbie
    Apr 2008
    36
    Default What would you do?
    To a car your going to drive all the way to africa, and over everything in your path.
    getting alsorts of conflicting answers, so i have come to the Gurus.
    This is the list ive got so far, anything non essential? missing anything?
    Big, burly fan on the front from an Astra GSI
    K&N filter
    Oil Cooler
    Spring Assistors
    Heat wrapping manifold -(are the standard ones Mild steel or stainless?)
    Sump + fuel tank guards - home made
    route the fuel line internal (out of the way) - is it worth getting mudflap hose?
    put in bonnet pins, hold it down over the really rough stuff. nececarry?
    Remember this is on a budget of around £0.10, we can get more, but selling the car in Cameroon, so not much point.
    also looking for all of these parts, so if anyone can help out, will be brill.
    Jan 2003
    SOMERSET
    19,510
    K&N filter? Fook that if you wanted the engine to last....
    Deffo decent shock absorbers from the likes of KONI or yellow bilsteins.
    Senior User Mike's Avatar
    Mar 2004
    26,594
    Id pick a car that is going to make it something that is noted for its endless off road & on road use. Not a bloody Nova.
    Aug 2006
    I live inside your pants
    4,527
    Quote Originally Posted by craig green
    Dislikes stupid people
    May 2003
    Nottingham
    11,405
    on the plus side, there is nothing you cant fix on a nova without some cable ties and gaffa tape.
    User _JH_'s Avatar
    Nov 2002
    South West Wales Drives: 2.0 8v Grasser
    955
    forget an astra GSi fan, use a corsa or Nova diesel rad and fan. You'll need a longer hose to the expansion tank, but you could ask a local scrappy nicely and just pick what you need from a scrap car.
    Definitely route the fuel lines inside the car. When you smash a hole in your tank, it'll make using a jerry-can easier
    Don't bother with an oil cooler. It'll be hot out there, but if you have a good rad and fan as mentioned it'll do the job. You won't be screaming the engine anyway - unless you're a chump.
    Forget heat-wrapping the manifold.
    Instead of bonnet pins, use bonnet rubbers like you often see on minis. bonnet pins won't line up after you've hit a gazelle at 60mph
    And finally, add to the post you put on the grasser forum that you want tyres. Put your location in there and you should find people nearby to you
    I have no experience of driving in extreme heat, but most of the problems experienced with over-heating are down to the existing cooling system being faulty.
    Sorry, need to get milk!
    May 2004
    Oxford
    6,666
    Ruddy good service before you go.
    Would it help not having a bonnet?
    I guess you'd end up with sand in the air box.
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    Quote Originally Posted by Matt2107
    and you would get pulled over prob, deffo in the uk its iilegal but i dont know and im just thinking...... (or lack of thinking)
    4th year Membership Scab Club Member Dod's Avatar
    Sep 2004
    Co.Donegal ROI Currently: has no Novas...
    10,651
    Big Burly Tyres on 14" Wheels, steels at that. They'll straighten with a Hammer, Bring Spare Red Hoses and a Rad. Go for a 1200cc Nova, a tough little engine, Tank guard and a Sump Guard. Astra Springs and as mentioned Billies or Koni's.
    If you could manage it, Cav TD Twin Fans? It'd be a squeeze but possibly worth it.
    I spent 90% of my money on Drink and Women, the rest I just wasted.
  10. #10
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    fit a diesel thermostat, it opens at a lower temperature, costs pence. I wouldn't bother with the fitting of a bigger fan, just make sure the one you've got works.
    take a 4 or 5dr nova because you can open the rear windows to help with in car cooling, & getting your stuff in & out will be easier.
    Remember this, GM took the novas to very hot countries to develop them. these cars will cope with the hot weather. The local fuel will be rubbish so take spare spark plugs
