Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Need to change Clutch cable and battery
    Newbie
    Mar 2008
    sevenoaks, kent
    45
    Default Need to change Clutch cable and battery
    how to change a clutch cable and a battery in easy steps as im a girl
    Senior User NovaLad's Avatar
    Feb 2007
    Oldham - Land of the Pie Heads!
    8,138
    Step to step guide on how to change a clutch cable and battery.
    Step 1: Pick up phone.
    Step 2: Dial the AA number (presuming your with the AA or such like)
    Step 3: Tell the AA your problem.
    Step 4: Wait for them to arrive.
    Step 5: Wait for the car to be fixed.
    Step 6: Be happy.
    This Guide was brought to you by NovaLad. Please ask permission if wish to use.
    Newbie
    Mar 2008
    sevenoaks, kent
    45
    not with a breakdown service
    nova van
    Jul 2007
    CRAWLEY
    414
    i will do it for you, its easy. Only in crawley
    Newbie
    Mar 2008
    sevenoaks, kent
    45
    need it done tomorrow tho, i know its short notice
    OMG! WTF? BBQ :) Lee's Avatar
    Jun 2005
    Newbury
    16,724
    In case he cant make it and you still fancy a crack at it yourself...
    Ill do this in the washproof and chewable version as I dont know your personal spanner rating .
    Battery..
    Tools..
    10mm spanner
    13mm socket with a long extension bar.
    1. Remove the Positive (red)terminal from the battery by undoing the 10mm nut on it (not all the way off). Tuck it well out of the way.
    Remove the negative (brown) terminal in the same way.
    Locate the 13mm bolt which will be at the bottom of the battery, at the front. Undo it, remove the clamp, and the battery will lift out. Refit is the reverse of the above.
    Clutch cable.
    Tools..
    Possibly a crowbar.
    Possibly a hammer and a blunt screwdriver.
    A Torch
    Get under the dashboard, and look up under the steering column, following the clutch pedal to its end. Look at the end of the clutch pedal (using the torch) and you will see a kind of hook with a small button on the end of it attached to the cable. You will need to pull the cable towards you slightly whilst twisting the hook upwards until it releases from the clutch pedal (difficult to explain but hopefully you'll see what I mean.
    Back under the engine bay now, pull the cable out from the bulkhead, and then follow it down to the gearbox (*which is located next to the engine on the right hand side of the bay.) it should be held in place by a large cylindrical plastic moulding, and then the cable itself is attached to a metal arm via a half cylindrical retaining clip.. Remove the cable from the arm by pulling the retaining clip towards the front of the car. Then you need to remove the large cylidrical plastic moulding by pushing it towards the back of the car. (this will probably be a tight fit so you may need to give it a few taps with a hammer and a blunt screwdriver.
    Fitting the new one should be done in a different order though. Firstly, attach the new cylidrical moulding to the gearbox. Then feed the other end of the cable through the bulkhead, get back under the dash and fit the cable to the pedal in the reverse of how you removed it. LASTLY you need to reattach the cable to the arm on the gearbox. You may need to get someone to help here by pushing the arm towards the car with a crowbar whilst you refit it.
    Lastly, get in the car and push the clutch in and out a few times to ensure its settled. If the pedal is sitting too high, you need to remove the retainer on the gearbox again, and unscrew it a few turns. Refit, and check again. If it is too low, you need to screw the retainer up a few turns.
    Hope this helps, its a farking difficult thing to describe
    Newbie
    Mar 2008
    sevenoaks, kent
    45
    cheers bbe x
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    please try to make your thread titles relevantish, I know your urgently after help, but some people might have an expert perversion towards clutch cable swapping etc and pass the thread by
    Senior User Club Member
    Sep 2004
    swindon
    7,906
    Mr Lee dont you know to remove the black wire first incase you touch the body of the car GGGGRRRRR.
  10. #10
    Jun 2005
    Newbury
    16,724
    Quote Originally Posted by Ernie
    True, that is the correct procedure, however ive always done posi first because im careful . Agreed that she should remove the earth first just in case.
    Dont even ask why I wrote all that Stu, boredom is a powerful thing
