ahhh, that was you! At a later date im changing to an Astra GTE one but just need the car on the road atm.
Cheers again
Cheers again
The larger mc unions are M12 mate.
Old XE track car
BLOX (again ) just ordered - will have to get something machined up then...
Give them a ring tomorrow see if they can swap them...
Old XE track car
couldn't see M12 anything listed under the euroquip 600 reusable fittings tho...
was going on this BTW
I think "Think Auto" sell them.
Old XE track car
Just googled them and they do! just mega confusing finding out what size everything is.
EDIT: just found it - ?18.85 + VAT + delivery, oh and plus the bolt
The hex bar thing is the original brake bias adjusters. they are still M10 X 1mm fitting though.Originally Posted by Ash
M13 ports on my Corsa master cylinder.
Assume you havent missed off the olives from your list Ash?
The slaves in the drums take an M10*1.0 Male convex fitting.
the MC takes male convex fittings.
the calipers take banjo bolts unless you fitted AP/Brembros etc then they might not.
