Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Nova Standard Wiring
    Jan 2008
    Northern Ireland
    1,673
    Default Nova Standard Wiring
    Hi people, I want to ask the PNG massive about wiring a CD headunit into my '91 Nova Trip.
    Its a run of the mill 45wx4 Kenwood headunit, and I want to know if my Nova will need any form of wiring kit to fit it? This website says I don't:
    http://www.nexxia.co.uk/Car_Stereo_f...xhall/nova.htm
    But most headunits have, erm, 2 rows of connectors encased in black plastic sort of? And mine has a single row of connectors to plug into? Or is it a matter of cutting and shutting a few wires?
    Sorry for the crap explanation, hopefully some people will be able to shed some light! Cheers
    -P-N-G-M-I-D-L-A-N-D-S Lee-170's Avatar
    Jun 2007
    Birmingham
    289
    Does your plug on your car look like the one on the right of the pic below?
    Jan 2008
    Northern Ireland
    1,673
    No mate its a single row of small flat connectors in a straight line which look like they make contact the same way that a memory card might?!
    Senior User Welsh Dan's Avatar
    Sunny Wrexham Drives: Derv barge
    5,467
    Then someone has either already plugged in an adapter, or lopped off the nova connector and fitted an aftermarket one.
    Jan 2008
    Northern Ireland
    1,673
    Ok wait a sec, I photobucket is working again now I will throw up a pic!
    Jan 2008
    Northern Ireland
    1,673
    Ok I have 2 pics, one of lots of wires and one of the connection I was talking about:
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Don't think I've ever bothered with wiring adapters, the first thing I always do is lop them off and match up the wires as I see fit with bullet connectors. I prefer to run independent power and earth cabling though rather than use existing car stuff.
    Jan 2008
    Northern Ireland
    1,673
    Ok cheers for the input Razorjack, I'm happy enough if I know that it can be done without wiring kits etc!
    Once I get the CD player I will let you guys know how I got on
    A E I Own U
    Sep 2007
    A Small Town In Kent!
    595
    Quote Originally Posted by Razorjack
    razorjack im having trouble powering mine with the wires i have from my car. How did u go about wiring and earthing a direct power source to your headunit?
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Easy, just run a suitable cable from the battery to the HU, with a fuse at the battery end. If its only powering a head unit, you should have enough room to trace the wire through where the main car loom goes into the engine bay.
    There's a couple of earth points up behind the dash, find the closest one and wire a decent gauge wire from the HU's earth to that point.
    Bear in mind the HU will have permanent live, so don't forget to switch it off when you leave the car
