Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 92
Thread: Help Needed Now!!! rear spring removal foolishness
  1. #21
    Senior User SRimon's Avatar
    Jun 2003
    Plymouth, Devon Drives: VX220
    3,143
    Oh my god
    just undo the strut inside the boot and let the beam swing away
    how to make removing the rear spring hard for yourself.......
  2. #22
    Senior User NovaLad's Avatar
    Feb 2007
    Oldham - Land of the Pie Heads!
    8,138
    Come do it for me
  3. #23
    Jun 2003
    3,143
    its a five min job
    mole grips on the strut top, undo the bolt, and your away...
  4. #24
    Feb 2007
    8,138
    I don't know anything about cars mate.
  5. #25
    Jun 2003
    3,143
    yet you managed to try and repair your rear arches, this is a much easier job
  6. #26
    Feb 2007
    8,138
    Right so if i jack it up liek it was today and then undo the bar thing behind the drum at the bottom and the nut thing in boot then what will happen will it all drop and the old spring go flying?
  7. #27
    Senior User Club Member
    Sep 2004
    swindon
    7,906
    you have a choice of undoing the nut at the top of the strut(inside the car) on both sides or undo the bolt at the bottom of each rear stut which ever you do the rear beam will drop down and let the rear spring come out.You will have to support the car on the sills which ever way you go about this job to let the rear beam swing down.
    Hope that helps or go get a haynes manual.
  8. #28
    Senior User Stoo's Avatar
    Jun 2003
    Northampton Drives: Audi TT
    6,073
    OMFG PMSL ROFLCOPTER!!! Nooooob
  9. #29
    User chris gsi's Avatar
    Sep 2005
    gloucester
    1,284
    spot on ernie i normaly put axel stands on the sills and put the trolly jack under the rear beam and remove the 2 bolts on the botton of the strut and then lower the jack the springs will fall out and then underseal where the springs go and then fit the new springs and jack the beam back up and refit the 2 bolts job done
  10. #30
    Dislikes stupid people
    May 2003
    Nottingham
    11,405
    OMG this was a funny read , also there is no reason to do the front on the car as well for the sake of two bolts an 30 seconds of your life.
