Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Supercharging an E16SE
    Member
    Feb 2006
    Northampton
    115
    Default Supercharging an E16SE - management query...
    If it's been answered before, then I apologise, but I couldn't see an in depth reply.
    Basically, I need to know what to do compression wise, does anyone sell low compression pistons, or would I have to use a spacer plate?
    Also, using an Eaton M45, does the throttle body need to go between the charger and the engine, or between the charger and the air filter?
    Cheers.
    Mar 2006
    wakefield
    551
    yes people sell low compression pistons dunno where tho not looked in to it but ive seem them about on the net, throttle body usually goes between charger and filter but i have seem them between charger n engine but usually in multi throttle configuration cant see it being good for the butterflies unless it has some for of bump valve or bypass which i dnt think the m45 has ?
    phil
    Jan 2004
    Yeovil, Zummerzet Fixing: 1650 Sport Wants: A 1.6 8v supercharged
    3,730
    mahle will do the pistons, dunno any suppliers tho
    Member
    Feb 2006
    Northampton
    115
    Hmmm, I think Mahle's head office is on an industrial estate near me, I know KKK have an office up there, but I'm sure Mahle are too.
    I might give them a call.
    If anyone else knows where else can do them though, that'd be great.
    Moderator burgo's Avatar
    Apr 2003
    kettering
    22,773
    11 Post(s)
    mvaux do them
    Member
    Feb 2006
    Northampton
    115
    Ok, next question.
    Will the standard management system cope with a small amount of boost with larger injectors, or am I dreaming?
    How do the turbo people normally do it?
    Sep 2006
    stoke on trent
    635
    theres a guy on here who had a c16se i think, he had some sort of swith??? with standard management. have you seen the replies in the 8v block 16v head thread?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    The standard management is set for standard fuel pressure, so large injectors will just flood the engine over the entire rev range.
    You need some way of upping fuel when on boost (i.e. aftermarket management which is mapped for positive pressure(boost))
    You can "bodge" it with a dual rate fpr, or a switch to "trick" the ecu into just dumping fuel in randomly.
    Member
    Feb 2006
    Northampton
    115
    I see.
    Well, it's a budget build, and I guess the FPR way is cheaper than a chip/remap?
    Where can I find a dual pressure FPR? Can't see any on ebay.
  10. #10
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Probably best emailing someone like courtney etc and seeing if they sell them seperately.
