Results 1 to 7 of 7
Thread: gsi keeps cutting out
    Senior Member
    Feb 2001
    4,624
    Default gsi keeps cutting out
    My car(1.6 gsi) is pissing me off big style at the moment,the problem is i can be driving along then all of a sudden it will cut out. then when i try and start it the bloody thing wont start.
    Then eventually when it feels like it itll start,this could be 10 minutes later or the next morning. Please can anybody help? x-(
    Senior Member
    Feb 2001
    4,624
    Default RE: gsi keeps cutting out
    you say it cuts out. well does it loose power a little then cut out, or do u mean it simply dies on he spot?
    Tried the common things like plugs/leads/dizzy.
    Maybe even fuel related
    Senior Member
    Feb 2001
    4,624
    i had this prob with my gsi.and it was the starter motor and brushes
    Senior Member
    Feb 2001
    4,624
    I had similar prob on my 1.2i, turned out it needed a new coil and ignition amplifier.
    Senior Member
    Feb 2001
    4,624
    it cuts out . it doesnt loose power ive tried plugs and leads, i guess ill try the distributer next, thanks for the ideas ill keep you posted.
    Senior Member
    Feb 2001
    4,624
    try the fuel pump relay, i had the same problem on my 92 gsi. they are ?12 from any vauxhall dealer.good luck
    Senior Member
    Feb 2001
    4,624
    fuel pump relay also switches the ecu
    16v Nova - Toolkit, Trouble, Points and great expence all come as standard
    2.0 16v back soon :D
