Results 1 to 6 of 6
Thread: presentation..need info..
    Aug 2006
    westmidlands (dudley)
    662
    Default presentation..need info..
    alrite...i need info on xe and let engined novas,
    weight (car stands with an ex and let engine in them, full interior not stripped)
    0-60 of them
    topspeed
    mpg
    power output and torque
    cheers.....need all this asap..as presenation is in about hour and need to type it up etc...
    Aug 2006
    662
    oh...need the 0-60/mph on f16 and f20 boxes....cheers
    Oct 2005
    Chorlton Manchester
    2,297
    XE performances can vary wildly mate, not least when you consider the condition of the engine , mileage, how well it has been converted etc. Also the ambient conditions such as wet roads or poor surfaces can alter your 0-60. Standard power (bhp) output of a C20XE is between 147bhp @ 6000rpm (mk 3 Astra etc) and 153 bhp @ 6000rpm (mk 2 Astra Champion). The torque figures can vary from standard between 144 LBF.FT and 150 LBF.FT both at 4800rpm. Bear in mind these engines are around 14+ years old now and probably won't make these sorts of figures though. The top speed won't be great as the Nova is as aerodynamic as a housebrick, and 0-60 figures don't really explain enough about how they drive as its not the ideal amount of weight over the front wheels to put the power down. C20XE Novas really excel in the 30-70mph etc department when traction is not as much of an issue. As you are combining a light kurb weight with reasonable power, your point to point speed will be very good (especially as you can hold speed in corners).
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    so will novaload get a reference in the presentation.......
    Jan 2003
    SOMERSET
    19,510
    Well at a guess I'd say he's currently stood infront of the class shatting his pants & wishing he did his homework...
    Aug 2006
    662
    ....presentation is on standby, aave done everythink i should have done and its so going to be the best in the class and whole mechanics department, just wanted to add some performance details, "stu" the only thing that novaload has in presention is pictures and novaload link
