Results 1 to 6 of 6
Thread: new engine
    Jun 2005
    swansea vally
    1,055
    Default new engine
    ive just purchased a c14se cylinder head (ported and polished) with re-cut valve seats, and a kent 320 duration cam and pully. the fella i bought it off said it would be good to rebuild the bottom end of my 1400.
    i was thinking would it be possable to fit it to a 1.6 bottom end as it would be stronger?
    also would i have more power?
    and what inlet would i use for a single twin choke weber?
    thanks jim
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    You can't use a single choke carb on a SE head as there aint a single carb inlet that matches the head.
    Iirc 14se head pushes compression up too high on a 1.6 block, so it would either be best fit it to a 1400, or get a 1600 block and head.
    Is the cam a hyd setup? Or solid lifter? Quite a wild cam there.
    Jun 2005
    swansea vally
    1,055
    yea ive got all the bits i need, yea the cam is wild. what should i use to rebuild the bottom end of the 1400?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Cylinder hone,new piston rings, main/big end bearings, ARP rod bolts, new oil pump...
    Depends on the condition of the engine to begin with, and how much you want to spend.
    Jun 2005
    swansea vally
    1,055
    i'll probably be doing it when i get a new job. dunno how much, whats about average? dont want too much power just reliability
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Probably ?400-?600
