I've recently finished installing a 20XE into my nova, but I cannot get it started...
i've got it to turn over, i've got fuel but no spark from the king lead.
i've tried 5 different coils and ign mods and two different ecus (both motronic 2.5)
i'm assuming the crank sensor works as the fuel relay clicks and the fuel pumps thru.
i've run a new ign live wire from the engine loom to the ign switch.
i've wired a temp ecu light, it stays on with ign, and flashes up code 31 - no rpm/crank signal...
any suggestions?
cheers
Ryan
