hi all,
is this possible?? if been offered a set of throttle bodies and i was wondering if you can run them on standard managment? obviously aftermarket managment is best, but costs...
thanks guys
hi all,
thanks guys
i beleive u will need after market stuff
was thinking of running them with the air mass meter and make a plenum to connect to the tb's.
still need after market lad.
If fitting it to a MPI engine, keeping original sensors etc, it might start and run, but the ecu map would be entirely wrong.
Not recommended.
Get a MegaSquirt setup to do it on the cheap. Just need someone/somewhere to finalise the spark/fuel map.
Old XE track car
iv heard there is a lot of engine failing with the megasquirt opition as they havent been put together correctly (dry joints) usaly with the injector wiring.
but it is a gd cheap price so i u get it done correcty and set up well it should be good for a laught
what engine u thinking about?
yes would need after market management, go for mega squirt its cheap enough.
You can get a fully/professionally built Megasquirt ecu for about ?250.
To run any engine you want.
Then just make a loom out of a few old Gm looms,Lol.
Old XE track car
make a new loom FFS... its not expensive and not hard. i wouldn trust 10 + yr old wires....
it when people have been making the looms.You can get a fully/professionally built Megasquirt ecu for about ?250
i mind iv heard something about a few of the ecu failing very quickly froma supplier and tthey have switched to emeralds systeams instead.
