Was taking the wings off to waxoyl the insides and came across this which I must add wasn't plugged in. Does anyone know what it's for?
The car is a 1.0 1987 Nova saloon.
Any ideas?
Any ideas?
Bttt
IIRC could be the headlight bleeper to tell you have left them on
Is everything (electric) working ok? windows, headlamps, dash bulbs, door locks?... where are those wires heading to??
think its a heat sink is it a mk1 interior had one of them in my gte as a differnce design but was from a biger engined loom so would expect it to be
Its the dim/dip relay i think. When sidelights on with ignition off your little 501 capless bulbs light, start car and your head lights light up but only on half power (dim) then switch to headlight you get full power (dip). Damn sure thats what it is. You found it on the drivers side? Were the shelf is if not connected to the shelf.
It's not connected to the shelf, it was contained in the cavity where the 2 bolts to the wing are. I'm heading down to my local Vauxhall dealer to see what it is.
When it wasn't connected everything worked on the car, didn't connect it up to see what happens though.
I'll post up what it is later today.
Cheers.
Dim-dip relay for headlights, I've yet to find one that works though
If there is a part number on it I can check on EPC to see if it brings up anything
yea thats the haedlight warning buzzerOriginally Posted by Ben
