Results 1 to 5 of 5
Thread: Removing Mk2 Dashboard!
    User andy_017's Avatar
    Jan 2005
    Manchester
    701
    Default Removing Mk2 Dashboard!
    I've just fitted some cavalier clocks into my mk2 nova, firstly i had a go at it with the dash in and have managed too get them in but they do not sit down far enough so im going to have too take out the dash and remove some of the metal from behind too make them sit down enough, does anyone know were i would start too remove the dash and how much of a big job it is to do this?is it just a case of unplugging everything and taking out all the screws etc etc? also on the cav clocks the speedo needle wobbles slightly, is there anyway i can adjust this or should i just find another set of clocks?
    Cheers Andy
    Apr 2005
    Down South
    178
    You dont need to remove the dash to fit these dials?
    If you cut away it will make it difficult to replace with originals if you change your mind.
    As for the wobble just double check the conection of the cable and that its not twisted or got to small a bend in it.
    Aug 2006
    scarborough!
    2,411
    read the guide at the top of this forum, that contains all the info you need
    Jun 2005
    Ilkeston
    13,425
    haynes manual is best bet to get the dash out buddy
    Jan 2005
    Manchester
    701
    Thanks a lot matey think i'll nip down to carcraft and grab one of them
