Thought he was running a 1.3 head?
1.6 head.
I ASSUME he got another dizzy the same as his old one?
Old XE track car
Yeah i found a mk3 astra LX with an 1.4 carb engine in it even had a pierburg carb. There was also a white nova with front spax srpings and cherry bomb 3 inch back box. I would have taken the bits but had no money and no space i am gonna get the timimg sorted cus i dont wanna blow the engine iam actually quite concerned cus iam skint and have to drive the car everyday how should i drive the car really tamelyOriginally Posted by Long Live The Nova
No mk3 astra's had carb engines, unless someones fitted a carb engine.
Perhaps it was a mk2?
Anyway.
-Set engine to timing marks on cam/crank
-Remove dizzy cap
-Either the dizzy itself, or the edge of it will have an arrow/cast mark
-Make sure the middle of the rotor arm is pointing at that mark
-If its not loosen the dizzy and turn it one way or the other till it aligns
That will at least get it running normal-ish.
Old XE track car
yeah mk 2 your right it runs fine and idles allright its just over 1k rpm so its not that bad i am just worried cus my rolling road is in 4 weeks time. So i might get a garage to sort my timing out so its ready for the rolling road. Why does one small thing have to mess everything up i know i shouldnt complain as i chose to modify my 1.4 but i suppose these things happen over time. I heard you can get modifed/uprated distributers someone i know, knows someone who builds them for fords at 115 quid a go? is it worth asking for an uprated oneOriginally Posted by Long Live The Nova
The 1400SR jobbie works fine, the engine modified isn't the reason for it to be running crap, if you set the ignition timing wrong on a std engine it would be exactly the same.
Do you not have any pics of your engine showing where the old dizzy was mounted?
Found one here:-
http://i2.photobucket.com/albums/y48...SCF1635new.jpg
See if you can set it back to where it looks in that pic, then get it set properly.
Old XE track car
