Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: sportex exhaust knocking?
    Club Member Club Member womble sri's Avatar
    Jan 2005
    Hertfordshire, United Kingdom, United Kingdom
    1,696
    Default sportex exhaust knocking?
    I fitted my exhaust system tonight at a friends workshop and we jigged the exhaust to give enough clearance of the tank it also sits quite close to the rear brake lines! is it just a bad design or am i missing something? any one else used these its the sportex cat by bass and cat back system for an sri although it was marked up as a gsi. but i had a long chat with the guy from online and he seemed to know his stuff so i doubt it.
    cheers neil
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Just sounds like classic Sportex to me
    Senior User Rich's Avatar
    Oct 2005
    Hampshire
    4,198
    Yeah terrible fit, my exhaust was fine, i then put a sportex manifold on (think the de-cat is sportex too?) and its now hanging about an inch from the ground. Catches on everything!
    Jan 2005
    1,696
    fukin hell i had heard good things about them too late too send it back now i suppose so i just have to put up with it knocking?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Whats it knocking on?
    I usually find turning the backbox helps move the entire system too, so you can move it away from the rear beam or whatever.
    Gold Club Member# 001 Club Member Nova_Tek's Avatar
    Jul 2002
    Hertfordshire..... Builds: ......... Snowplough'd LET
    8,107
    Yeh thinks its a usual thing that happens.
    My sportex back box bumps against the rear suspension spring going around right handed corners and somtimes if I move off and use too much clutch it'll knock too. This is on a standard nova mid a front exhaust. Plus the tailpipe sometimes rubs against my bumper cutout (MK1 bumper)
    Which was why I was about to start a new thread asking the best exhaust for a MK1 Nova. Best sound, best fitment & best look.
    Lets hear your opinions people
    Nov 2003
    Austin, Tx, Usa
    24,200
    mines fine thanks
    altho its not a sportex, but its a 100% copy of it
    User rednova's Avatar
    Nov 1999
    newcastle
    1,188
    mine was a nice fit when i got it so was my mates astra system after he'd told me he'd only put the mounting bracket on to stop it rattlin (read as wrong way round - muppet that he was ) i loved mine sounded great not raspy at all nice deep rumble if they are knocking as posted before try twisting box - generally helps plus consider buying new rubbers with a harder compound?
    Mar 2006
    west midlands
    896
    you need to cut some sou of your bumper and try pushing the box on more or off more if you know what i meen because mine was close to my spring untill i did this. ill get some pics 2nite
  10. #10
    Jan 2005
    1,696
    we got it over the pit last nite opposed to the ramp so we could put it in between the rear beam and tank with it sitting normally and it didnt knock with four people in it. it did knock a couple of times on the way to work today but they are real bumpy roads. when we were under there it looked as though the whole thing could of done with going back an inch then the pipe would miss the beam and the tank and to be honest the brackets arent that spot on any way so considering making a sleeve to give a bit more adjusting but oonly if i start having problems. it does hang low though just had a look at the ashley system and manifold on my sr and that sits nicely and never knocks although could do with some harder rubbers as it swings quite a bit.
