Results 1 to 6 of 6
Thread: leaking nova!
    User andy_017's Avatar
    Jan 2005
    Manchester
    701
    Default leaking nova!
    anybody have any idea were this leak could be coming from? whenever i leave my car parked on a hill a large puddle of water appears in the drivers footwell when it is parked facing down the hill and a puddle will appear in the back on the drivers side when it is parked facing uphill!?!has anybody had this problem before as its really annoying and i cant figure out were its coming from? i've got gsi sideskirts on my car but i dont think it could be anything to do with these. Please help. Andy
    Small and Shiney Dar's Avatar
    Jul 2004
    Bellendshire Drives:DPi Edition Nova
    6,567
    First port of call is under your battery.
    NW BOYS Club Member Riggy's Avatar
    Jul 2003
    United Kingdom
    11,735
    as dar said check that battery trayhasnt rotted through , also check that the grommit behind the battery is still there and also check your door seals
    Jan 2003
    SOMERSET
    19,510
    My battery tray has a hole in the bottom for a screw or something.
    Windscreen rubbers can let moisture through aswell with some pretty drastic rust as a consequence in an area you never knew existed. (up in behind the bonnet hinges).
    Jun 2005
    Ilkeston
    13,425
    what about sunroof ?? ive got 1 dismantled and there to small rubber hoses stickingh out the front which im assuming are for drainage ??
    Oct 2005
    Chorlton Manchester
    2,297
    My car leaked through a hole with a cable running through it in the battery try where some bright spark has not replaced the grommet. Made a little puddle on the mat under the clutch, temporarily sealed it with a bit of blu tack! Thank god for rubber mats!
