Guys,
Decided to finally get around to doing my central locking and leccy windows today. Everything was going fine till I tried the central locking. It's Vauxhall, not microscan, but it doesn't work right. Basically, the drivers door motor is working fine, as you can hear the relay clicking, and I've tested the slave wires using a test light, and it's diffinately sending a signal, so whats wrong? I'm guessing that it's the passenger side motor wiring, as when I've swapped the motors over they work fine. So how should it be wired? The motors have 6 pin connectors, so which pins should the 2 wires be going to?
Cheers!
Chris
