Results 1 to 9 of 9
Thread: cost of lowering...
    Senior Member
    Feb 2001
    4,624
    Default cost of lowering...
    Hi
    well now i know what to get, i went and founf out how much it is to fit it
    120 quid from a garage near me, is that a good quote on changing springs all round ?
    I cant do it myself caus i dont have the spring compressor thing, and the time...
    Senior Member
    Feb 2001
    4,624
    Default RE: cost of lowering...
    Just for the springs ?
    Senior Member
    Feb 2001
    4,624
    If its for springs and fitting it's Ok, If it's for fitting only its way over the top. Don't you have any mechanic mates that could help? If you know an apprentice mechanic I'm sure they will do the job for about ?20-?30 its fairly straight forwards.
    Senior Member
    Feb 2001
    4,624
    the back is easy the only hard bit is getting the nut off the top of the fronts!! do it yourself apart from compressing the front springs and the top nut just get a local garage to do that bit
    Senior Member
    Feb 2001
    4,624
    I'am getting my springs put on for ?40 squid !!!! i would tell them to shuv it where the sun don't shine
    Senior Member
    Feb 2001
    4,624
    You can pickup springs for about ?60. Try and get someone who knows a bit about cars - they should have no problems fitting Nova springs as long as they have the right equipment, slip them ?20 then thats a total cost of ?80, saving yourself ?40!
    Senior Member
    Feb 2001
    4,624
    jeesh
    yeah, that was just for fitting...
    Senior Member
    Feb 2001
    4,624
    What ste said makes a lot of sense, do the rears yourself (easy) and take the front struts to a garage to get them done, it will take them about 10 mins to do.
    Senior Member
    Feb 2001
    4,624
    If you`re dropping it 60 the uprated front shox make a lot of sense, I thought it was a load of bollox until I compared the old gte shocker to the new sports one. Ther damper rods are shorter on the sports units, they`ll lst a lot longer and less chance of bottoming out.
