Does it fit straight in or is it a pain in the arse?
I mean to fit a mark 2 dash into a mark one.
i found it fitted straight in a few mods to the heater box though just adjust the vent pipes. make sure you get all the connections aswell and compare the numbers on switches to the ones on the old ones you will find most numbers match then just switch on wire for another best do 1 at a time though
it will fit no problem only that yo may find the oil gague dosent work
