Results 1 to 5 of 5
Thread: My fucked speedo
    Senior Member
    Feb 2001
    4,624
    Default My fucked speedo
    my speedo will be ok up till about 40mph, then it will just start making a whirring type noise and the needle bouces between 0-120mph, sometimes it will just hang down and other times it will say im doing about 75 when i know im only doing 40, and sometimes its fine. i changed the speedo cable and checked the fixing on the gearbox and they are fine, checked the back of the speedo and it looks ok, anychance its the clock thats fucked....maybe the cogs inside or something. i know it aint the cable or gearbox as the milometer works fine. HELP!!!!!!!!!!!!!
    Senior Member
    Feb 2001
    4,624
    Default RE: My fucked speedo
    if you are local i can sort if for you if it is the clocks but it sounds like it could be the speedo attachment on the gearbox
    Senior Member
    Feb 2001
    4,624
    Well I have a set of clocks with white dials it you want them mail me.
    Senior Member
    Feb 2001
    4,624
    ste, what do u mean? i reckon its fine. the milometer is fine aswell. could it not be the actual clock thats fucked?
    dan, how much u want and where r u?
    Senior Member
    Feb 2001
    4,624
    ste is there anything i can do? can i take out the speedo clock and open it up? anyway the noise is coming from inside the clocks and only happens when the needle bounces
