Wot about new cam followers m8, c if u can get em cheap cuz most places charge u ?50 a set. But i think i can get em for ?30ish!
If u dont get new followers and u use a high lift cam ur car will sound like a tractor after a week!!!
Dicko
Dicko
no mate im having the cam kit, so they will be in the kit. thanx anyway
M8 whilst u're at it why not get the head flowed so the cam carb and zorst can really do their thing?
The only real way to check is to measure the bores (side-side and front to back) with a caliper and compare it to what they are supposed to be in the haynes manual. If you feel down the bore you might feel a ridge where the piston rings stop at the top if it is bad. You could also measure the crank to see if there is any wear.
