I've got a stupid problem with my Nova!
It's an Antibes, but I've got a 1.3 SR engine in it, with the Pierburg SINGLE choke carb.
It's perfectly fine most 99% of the time, starting instantly, smooth even power delivery, mint throttle response etc, but it buggers up as soon as we get a certain type of weather.
You know that really fine rain, that wets you through, without you really noticing? Well, the problem happens when it's like that.....it's fine in very strong rain, and cold, and snow and icy weather, but not when it's like that.
Right, I suppose I out to tell you the problem !
it starts by the car suddenly feeling under-powered, and it starts slowing down, then speeding up and again and again, but very subtly, so you hardly feel it.
It then gets worse and worse until I have no power at all, and have to stop.
I've I put on gas the engine really struggles to rev, and it makes a dodgy put put put put noise, before finally dying.
If I then try to re-start, it just turns over and over, with little or no signs of firing.
BUT, if I leave it for a minute or saw, and try starting again, it's fine! I can then usually drive all the way home again, with no problems!!!!
Is it my carb, is it the ignition?? I suspect it's the carb, as I know it's not the right one for the car (from my old 1.2!), but I had this problem with my last engine, and that had a dodgy distributor. So, I've got the same carb, and the same problem, but a different engine and a different distributor! HELP! please.
