I am running my Sr on lrp. is it safe to change to unleaded, its a 1991 1.4sr. what performance changes am i likely to endure?
I'm running unleaded.
it's safe dont worry, plus unleaded is alot cheaper.
Thanks for clearing that 1 up GSI boy!
If your car was designed 4 4 star/LRP , you will get better performance running on it rather than unleaded. I had mine changed to unleaded, and fould the carb was over fueling, which ment I wasn't getting the performance I should have, so I went back to LRP.
i forgot, it will proberlly run beter as well.
After 85' all vauxhalls had hardened vave seats, so unleaded should be fine. Ignition timing will have to be changed by about 3 degrees as the lower octane rated fuel doesn`t resist pre-ignition as well(not good). You will get more power out of LRP or super unleaded as the point of detination is at a better part of the cylinders cycle. I thought 1991 sr were on unleaded anyway? mine was until I modded the engine and changed to LRP. See this months fast car for their feature on fuels.
My 88 GTE has always run on unleaded, no problems yet (Oh now I`ve done it!)
1991 should have been running on unleaded anyways
I thought that as well
oi oi swansea sainsburys 76.8!!! ul. i put some super ul in it the other week, fecking hell what a difference, its ok for a once off laugh but not a tank full to much ???
