Wats da best way 2 lower a nova? is it 2 heat da springs and drop her down or 2 buy custom lowering springs?
typing like a human being is a good start
"custom" lowering springs/shocks is the best way out of your two ideas
cut the springs in half then go for a top speed run to see if they have "bedded" in properly
helpful advice guys! Neil just get some lowered springs, saves you the hastle & way way safer!
Originally Posted by Philsutton
well thats some reputation points for you
as for the post , try get a full kit if you can , because then they will be matched ,
if you cant afford the kit and go for springs only , dont go more the 40mm as they will just bottom out
ha ha ha ha, helpful as always phil !!
