Right Ladz\Laydees, I am soon gettin a 1.8 16v DOHC engine and box for my 1.4sr. I understand I need the engine, gearbox, inlet manifold, airbox, wiring loom and ECU. Have I missed anything? Anything else taht I will need apart from the obvious???
exhaust mainfold and downpipe coil and module
Will it fit without modified driveshafts ect? What gearbox does it use?
Brakes.......... Standard 1.4 SR brakes are cack!
Why dont u save yourself a lot of grief, time and money and buy my rapid GTE?
GTE's are shite!! Onse my car is sorted I'll eat GTE's for brekky!! Thanks for the tips guys..
GTE's are *****?Erm.. ok then.U spend ???'s on getting ur 1.8 16v engine put in and all the bits, balancing etc to make it run and then dont be upset when u get whooped by a lighter car, with a lighter engine and more horsepower per tonne/engine capacity.I seen it done mate,2.0 8v nova lost miserably to my GTE, go 2.0 16v properly or turbo or dont bother.
I think u will need to change the fuel tank as when I had my Mk1 Astra 1.3s and converted it to a 1.8i I had to change the fuel tank as carbs run on different fuel pressures compared with injection. Also have u thought about engine mounts and having upgraded front suspension for the extra weight.
Clutch, speedo and acceterator cables may be usefull. Fuel pump, just in front of the tank usually. Header tank?
SEF mate, u don't seem to understand, this baby is a 1.8i 16v DOHC. No 8v rubbish!! Let me get my shit sorted then we will c! If ur right and a GTE does woop my ass then pigs might fly....
