Results 1 to 5 of 5
Thread: Camber adjustment
    Senior Member
    Feb 2001
    4,624
    Default Camber adjustment
    I`ve nearly fucked the inside of both front tyres (205/40/17) because of lowering it. How long does the top hole have to be elongated for a -40 drop, 8 inch tyres to sort it out? (It`s an `88 GTE). Any help / tips would be apreciated as I`m butchering my shocker bottoms tomorrow.
    Senior Member
    Feb 2001
    4,624
    Default RE: Camber adjustment
    okay kieth listen to this
    i stuck a new set ov pirellis on 1 montn ago and now there getting replaced coz theres no tread left.tracking adjusted itself sum how and camber fucked em up
    i did mine on new years eve in the pissing snow.
    what i did was mark outwards about 9mm and redrilled the top mounts. wacked it all back to gether and got it retracked. i still have a small amount ov negitive camber on the front "which u need really" but now i get to use all ov my tread instead ov just the inside 10mm!
    minesl lowerd more than yours so i would say half my measurements and u should be ok
    make sure u are meticulous about your marking and drilling coz u dont want em wonky
    u got the arches yet? i was offerd a set ov 4 widearches 2 days ago for ?100
    Senior Member
    Feb 2001
    4,624
    if your running 17" on a 12 year old car i'd take bets your bushes are fucked
    Senior Member
    Feb 2001
    4,624
    Cheers Micky, I`ve gone out 4 mm and it seems to have done the trick, can`t reall tell without a camber gauge. May fit the track control arm kit if it`s still out and get it set up professionally. I`ve got the rear arches ready to fit when the weather picks up, I`ve allready performed major arch mods (rebuilt the rear buckets for max clearance, using my new mig welder i got for crimbo ) Ste, I`ve had a play with the bushes and they seem ok, may replace them anyway to be on the safe side.
    Senior Member
    Feb 2001
    4,624
    same ere im gonna renovate my car after the winter coz the back arches are shot implanning to redo the sides after all the winter shit passes
