Results 1 to 7 of 7
Thread: nipples!!!!
    Senior Member
    Feb 2001
    4,624
    Default nipples!!!!
    two things:- what does it mean when they say that they will grease your nipples when u have a service???? am i going to the right place??!! or have my mates taken advantage?!
    also whenever i do a right turn on full lock then there is a tapping. the faster i go then the tapping increases. it is when i am full lock
    is it some kinda bearing or joint going or something not worth worrying bout! also the tracking is out since i had me springs fitted!
    cheers in advance
    dan
    Senior Member
    Feb 2001
    4,624
    Default RE: nipples!!!!
    tapping sounds like cv joint on way out, mines the same.
    nipples? :-/ maybe the bleed nipple on the calipers?
    Senior Member
    Feb 2001
    4,624
    Back in ye old days when stuff ran on steam etc. You had to lubricate everything everytime you went any where they were known as grease nipples. Hence the saying greese your nipples!
    Also in this house round the corner there is this big blonde bird. Who for a mere ?30 will not only greese your nipples but flush your system out aswell.....and if your not up to pressure blow you back up.....and then she will..........................any way hope that helps.
    Jimbo (Old dirty bastard)
    Senior Member
    Feb 2001
    4,624
    lmao @ jimbo yeah think its my mother
    Senior Member
    Feb 2001
    4,624
    my car taps in full lock to the left only and only when i reverse.
    Senior Member
    Feb 2001
    4,624
    tapping is outer cvs ?45 per side fitted
    Senior Member
    Feb 2001
    4,624
    cheers lads and jimbo whats the number of the blonde bird??
