Results 1 to 10 of 10
Thread: Heated Screen Light
    Senior Member
    Feb 2001
    4,624
    Default Heated Screen Light
    Is the dial that you pull out for the rear heated screen meant to light up to let you know it's on? I keep forgetting.....
    Senior Member
    Feb 2001
    4,624
    Default RE: Heated Screen Light
    yes but mines stopped working !!
    Senior Member
    Feb 2001
    4,624
    I don't think the mk1 one does, mine never has and there's no obvious bulb
    Senior Member
    Feb 2001
    4,624
    Yeah the MK1 does' mine works fine!
    Senior Member
    Feb 2001
    4,624
    where's the light then ?
    Senior Member
    Feb 2001
    4,624
    I presume it's the yellow centre of the dial that lights up as opposed to a dashboard light??
    Senior Member
    Feb 2001
    4,624
    i havent noticed on my mk1 but my mk 2 doesnt light up but it looks like it should
    Senior Member
    Feb 2001
    4,624
    I think it lights up when you have have your lights on.
    Senior Member
    Feb 2001
    4,624
    mine did work when ever (lights on and off) but now the bulb has died and i can be arsed to change it
    Senior Member
    Feb 2001
    4,624
    The actual switch center will glow dim with the ignition on and bright when the switch is on.
